Steering Box Identification Help
No tech discussion, please
Blue_Streak
Post by Blue_Streak »
I have two steering boxes and I don't know what they came out of nor what make they are or if they are manual or power. I was hoping that you good folks might be able to help me if, it is possible, in identifying them through the numbers on them.
They both have the same numbers. When facing the exact same way , one is right side up and the other is upside down.
D 1 (or is it a /) TR-3550-BA Now there is a small set of numbers , both near the shaft side of the casing. One is what looks to be 257 and the other one looks to be 301.
Also, on the casing of the shaft there is also some numbers. One has C7AR on top and 3A587-A below. The other one has CFB ( I think ) on top and 330 below.
So, with that info, can anyone familiar with steering boxes able to tell me what I have?
Also , any idea of what they are worth?
Thanks guys.
Blue_Streak
Re: Steering Box Identification Help
Oops! Maybe I should have put this in Suspension / Steering / Brakes section.
Mods please move if you wish.
sargentrs
Post by sargentrs »
FLASH 1
Post by FLASH 1 »
Manual 2wd gear boxes are a 3 bolt top cover and interchange from 65-79 but Pitman Arms change
Bendix Bolt is 4 bolt top cover 66-68
Ford Saginaw Box is a 2 Bolt Top Cover Power Steering Box used from 69-79 F-100/250/350 2wd trucks but use different Pitman Arms on 250 over 8000 GVWR'S and all F-350's
some boxes should have a metal tag on it as well
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
Blue_Streak
Thanks sargentrs . I had a look through that and none of their numbers corresponded to mine.
Blue_Streak
@FLASH 1
What do you mean when you say "top cover"?
I did a google search of the number D1TR-3550-BA
D refers to 70s
1 refers to year of truck or when the latest revision came out so in this case it would be from a 71 or later with the latest revision being from 71
T refers to truck
R not sure
3550 refers to the whole unit being a steering gear assembly
B ?
A ?
One guy had the same number and it was an original power steering box from a '75. One guy sold one on ebay and he claimed it was a power steering box for a '73-'79. Mine has the FORD logo stamped on both. Would that mean they are both Ford Saginaw? Also I guess since its a 71 or later then it would have to be Saginaw right?
Blue_Streak
and upon further inspection, they both have C7AR 3A587-A cast on the input shaft housing
sargentrs
Post by sargentrs »
Here's mine. It's an original '71 Saginaw power steering gear box. Looks like the same numbers. See those 2 hoses/lines on top? Those are power steering hoses. A manual unit would not have those or the ports they screw into.
Blue_Streak
Well duh!!! How stupid am I. Of course they would be ports for the power steering lines. Makes perfect sense now that you mention it. I looked right at them and never thought twice about them. Just concentrating on the numbers to even see the ports. Mine have exactly the same thing.
Thanks so much for your help Randy and Tom.
And just to show you that the learning never stops …..
one of my 1971 Ford Saginaw Power Steering Boxes has a thingamajiggy bolted onto the bracket at the top. Its got lines coming out of it as well. And if I could ever figure out how to post pics like you just did I would post a pic of it. What is it called and what does it do?
I'm learning this mechanic stuff by trying to do work on this rebuild so the correct terminology is not always there. I have learned a TON of information from this site and is my go to place. I don't contribute a whole lot, if anything, 'cause I don't know very much.
And Randy...… I watched your youtube slideshow on column rebuild. It is my next big undertaking and had no where to start before watching that. Now I have a clue what to do. Thank you for making your channel.
Blue_Streak
Any idea what these PS boxes are worth?
FLASH 1
Post by FLASH 1 »
Top Cover is where the adjustment Screw is
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
sargentrs
Post by sargentrs »
Blue_Streak wrote:And just to show you that the learning never stops …..one of my 1971 Ford Saginaw Power Steering Boxes has a thingamajiggy bolted onto the bracket at the top. Its got lines coming out of it as well.
Kind of something like in this maybe bolted to the bracket like on top of my steering gear?
https://www.fordification.com/tech/propvalve101.htm
sargentrs
Post by sargentrs »
Blue_Streak wrote:And Randy...… I watched your youtube slideshow on column rebuild. It is my next big undertaking and had no where to start before watching that. Now I have a clue what to do. Thank you for making your channel.
Thanks! Here's the writeup I made the video from. More details and better pictures. http://www.fordification.com/forum/view ... hp?t=72274
What are they worth? In useable condition, without rebuild, i would say $50-$75. But then, I'm a cheap bast**d. :lol:
Here's how I post photos from my computer https://fordification.com/forum/viewtop ... 569200cb08. Same process applies to a phone. The trick is getting the pics file small enough to upload, under 500kb. I find that if I view my photo, then take a screenshot, and crop it down it's usually small enough. My phone takes 3 Mb photos but that works for me.
Blue_Streak
Blue_Streak
Yay Me !!!!!!!! :D
Thanks Randy. Your tutorial on how to do it along with a Photo Resizer app did the trick. My photos were too big. Then I got the app.
So..... what's the thingamajiggy on top called and do?
