crankcase press
crankcase press
what causeses crankcase press in a 302 and how do you fix it thanx
65 F100 swb 302 project
67 dodge coronet 440 also wife's car great mopar though
2005 dodge ram 3500
2008 dodge ram 1500 cc
2005 dodge ram 3500
- BobbyFord
Re: crankcase press
Need more info.
If the PCV system is functioning properly and the crankcase pressure is excessive then it's probably piston related (bad rings, damaged piston, etc.) Compression is leaking past the piston, into the crankcase.
Re: crankcase press
there is no pcv system it is just motor and vlve covers
2005 dodge ram 3500
2005 dodge ram 3500
- Redcap
Re: crankcase press
Hook up a PCV.hot_roder09 wrote:there is no pcv system it is just motor and vlve covers
- BobbyFord
Re: crankcase press
Why not???hot_roder09 wrote:there is no pcv system it is just motor and vlve covers
Re: crankcase press
Someone was going racing I would assume.
Re: crankcase press
no just never had one figured i would not need one i hoped
2005 dodge ram 3500
2005 dodge ram 3500
Re: crankcase press
The internal engine pressure will cause massive leaks if you do not have it vented or hooked to a PCV system.hot_roder09 wrote:no just never had one figured i would not need one i hoped
- BRUTUS_T_HOG
Re: crankcase press
that could be normal blow-by. how much pressure is being produced?hot_roder09 wrote:there is no pcv system it is just motor and vlve covers
ASE Certified Technician
- ezernut9mm
Re: crankcase press
unless you have a road draft tube from the intake then you need a pcv system of some sort. the early car fe's had that, but i dont think any windsors did. both valve covers should have a vent even if you don't use a pcv valve. something as simple as breather style fill caps will work.
Re: crankcase press
Ye old road draft tubes ouch. The early small block V-8s had them as did the 144, and 170 I6. I had a 63 Falcon 170 I-6 that had pcv but a friend with a 62 Falcon and 144 did not. By 65 my friends with Mustangs had PCV but my factory racer 67 390 fastback had two breathers from the factory and a friend that had a Factory 68 Torino racer with 428 also had 2 breathers.
Two breathers were a mess as all engines breath a little oil out so it was all over the valve covers and was part of the daily clean wax tune that kept the factory racers as super sleepers on the street.
Re: crankcase press
thanks guys i am goin to try the pcv and two breathers instead of the one and see what happens, just checking the pcv hooks up to the back of the carb correct
2005 dodge ram 3500
2005 dodge ram 3500
Re: crankcase press
With pcv you will only want one breather on the opposite side of the engine, As far from the breather as possible.
- Ranchero50
Re: crankcase press
With the pcv setup hooked up take the oil fill cap off and while the engine is idling if it's smoking out the oil fill hole in the valve covers theres not much you can do to fix it except rebuild it. Valve seals and rings are leaking by or the PCV system isn't drawing any air...
Re: crankcase press
cool thanks but hte motor is suppose to be new and the valve seals are also new i just out them in the are the one's from comp cams
2005 dodge ram 3500
2005 dodge ram 3500
