360 to 390 build up
360 to 390 build up
hello blue oval buddys, im considering changing my 360 into a 390 or possibly more. what would make this possible other than the 390 crankshaft
Re: 360 to 390 build up
.......and 390 connecting rods. That is the only difference between the two.
- 69rangerf100
the crank is also different
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
- 70_F100
That was already mentioned...69rangerf100 wrote:the crank is also different
That's not an oil leak
You also need 390 pistons because 360 pistons have a different pin hight.
360 pistons have the same pin height as 390 4V car pistons(1.76"). The 390 2V(1.66")truck pistons have a different height.hazelnut wrote:You also need 390 pistons because 360 pistons have a different pin hight.
I'm using 360 pistons in my 390 build and will have a compression ratio around 9.6:1. It is pretty confusing, isn't it.
Not really the .10 allowed the pistons to jump motors nicely and lower the compression for the trucks at the same time.
360 to 390 must haves are crank and rods, nice to have are pistons and cam. A Car cam from 67 or 68 will wake up a 390 but the 360 truck cam yawn.
today i found the donor crankshaft and new connecting rods. im debating the pistions. i dont plan on tearing back into the block but i dont want to spend it all at one place
. i have a mild cam and 4barrel intake. ive had headders for awhile but thinking of returning back to stock manifolds.i have been told to run 428 heads but dont plan on running over 6,000 rpm's
turns out the connecting rods were for a falcon. anyone know a way to tell if they will work such as factory part numbers? i dont want to buy the wrong parts or get screwd out of money
It does not matter what car they came out of but what engine. Oh and if the Falcon you are referring to had a stock engine in it it was never a FE. They were born with the small six line and died with the 289/302/351W family.
thanks for the info
