Late model heads on early model 302
I have a 1971 lwb with the original 302 I'm wanting to go through and do some upgrades. I have read all about the the GT40 and E7 heads as a good upgrade. Long story short, I came across a set of E8JL heads out of a boat with a 351W which had a cracked block. I got the heads at a good deal along with the pistons and rods, cam and lifters, and crank. From my searching I have found these to be 5.0 heads, not 351W which I had wanted. But anyways, I figured they would be in the same league as the E7 truck heads. Can anyone give me anymore info on these heads? CC, valve size, etc? Also I'm wanting to upgrade to roller rocker arms, how much work would be involved in this process? I have searched 'other' forums for answers. But I've learned, if it has to do with a bump, this is the place!!
I can not say enough about this forum. Anytime I have a question I usually do a search, and there's the answer. If not, leave a post, and there's the answer. For this I say, Thank You!!
Hope for the best, prepare for the worst.
Re: Late model heads on early model 302
Man why not throw some 351w heads and intake on there? And a 351 w cam, and use the 351w firing order. I bet hads be beast.
do a google search on the head numbers you are interested in. E7TE-xxxx-x fill in the xes and do the search.
- FreakysFords
Showing 52 to 58cc chambers according to what I can find from a friend. Need full info from heads and "might" be able to figure out more.
- wt4speed#2
I tried as well with the (E8JL) number came up with 1988 industrial application .The (L) in the 4th character isn't defined(in this chart ) . Here is my source:
http://raceabilene.com/kelly/hotrod/engine3.html
http://raceabilene.com/kelly/hotrod/engine4.html
Might check the #'s and try again. also a lot of good SB ford info here.
http://www.mustangsandmore.com/ubb/Foru ... 10959.html
http://www.crownvic.net/ubbthreads/ubbt ... 904&page=1
4th or so message gives cc s.
http://www.mustangevolution.com/forum/t24533/
alot of opinions from my google search
Thanks again for everybody's help. So far I came up with E-1980 8-1988 J-Industrial L-Marine. Also I came up with a date code of 1990: 0F8(1990, June
& 0B14(1990, February 14). Is this correct?
freakysfords, what info do you need? Pix, casting numbers, date codes, etc? I'll get whatever you need, I'm at a stand still. And one more thing the casting numbers are: "E8JL AA". If that helps any. I know it means there were many revisions to this head ie: A,B,C,D,...X,Y,Z,AA. But any info would help.
That's supposed to be: 0F8(1990, June
. Don't know how the cool sunglasses made it in there.
Dang it!! Again!! It's an eight!!
- FreakysFords
Whatever you can give me (pics too would be great) and I'll pass it on to him. He has been the local Ford Parts MGR since the early 80s and over the course of 12 yrs, I've yet to hit him with a part that he couldn't name me the part number to. Sadly we no longer have a Ford dealership as it was bought out by an idiot who ran it into the ground and Ford shut him down. The man's name is Greg and he now works for ahickchemistry07 wrote:freakysfords, what info do you need? Pix, casting numbers, date codes, etc? I'll get whatever you need, I'm at a stand still. And one more thing the casting numbers are: "E8JL AA". If that helps any. I know it means there were many revisions to this head ie: A,B,C,D,...X,Y,Z,AA. But any info would help.
