360 performance mods and more
Well I have a pretty good 360 outfitted with headers, performer intake, and 600 cfm edelbrock. Are there any other avenues I can take, or is it best to try and turn it into a 390 and if so how. Also I have a 70 swb donor truck, old owner told me it is a 390 sitting in it, but it is marked 352 on the block (same as my 360) are they all marked this way or have I been duped?
- 68CamperSpecial
Re: 360 performance mods and more
I'll take a shot at this. I'm surprised there are no responses with a bunch of
:bdh:or
The 352, 360 and 390 are all the same block. You have to measure the stroke to find out what engine(do a search, there is a TON written on this subject).
I also have a 360 and I read here that you can put a 428 cam in and make it a 410. Something to consider.
-CKB
-CKB
Learning something new about these trucks every time I log-in
- 70_F100
Correction.68CamperSpecial wrote:I also have a 360 and I read here that you can put a 428 cam in and make it a 410. Something to consider.
-CKB
You can't change the cam and increase the cubic inch displacement of an engine...
That's not an oil leak
- hotrodfeguy
Yea you have all the quick and easy done, now go for more cubes.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
360, 390 and 410 are the same block, a 352 has a smaller bore although it is externally the same.
You can change the rotating assembly (crank, rods, pistons) and make a 360 a 390 or 410 relatively easily. There are also some stroker options. in the case of a 410 you will either have to use a 410/428 flywheel or flex plate or have the crank internally balanced with Mallory metal.
There have been myriad threads on this, spend a day in the search and you should have most of your questions answered.
- ToughOldFord
- ToughOldFord
whats the best way to get horsepower and torque out of a 360?
- 70_F100
Convert it to a 390!!!redneck71 wrote:whats the best way to get horsepower and torque out of a 360?
ya i could do but what are some good performance parts for the 360?
- sideoilerfe
They're the same as the 390. If you want to go fast, get a 390. If you want a workhorse rebuild the 360. The 360/390 blocks are the same. Same casting numbers, same bore ect. As mentioned, do a search and you'll find all the answers. This has been discussed countless times here in the forums.redneck71 wrote:ya i could do but what are some good performance parts for the 360?
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
ok thanks
soulcrushing71 wrote:Well I have a pretty good 360 outfitted with headers, performer intake, and 600 cfm edelbrock. Are there any other avenues I can take, or is it best to try and turn it into a 390 and if so how. Also I have a 70 swb donor truck, old owner told me it is a 390 sitting in it, but it is marked 352 on the block (same as my 360) are they all marked this way or have I been duped?
Addendum: If you're looking to improve on a budget, ditch the Edelbrock carb and get a Holley HP or a Demon- huge difference in my experience. Also, ditch the Performer and get a Streetmaster of Performer RPM intake. You might just want to do a basic rebuild on the 390, and add your performance parts to it- would be a BIG upgrade.
