Stripped head bolt hole
OldRedFord
Post by OldRedFord »
A while back I stripped out a head bolt hole on my 460. Havent fixed it yet. Just thinking about running a tap in the hole to clean the threads and call it done.
What do you think?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Stripped head bolt hole
That should work.
There are two different length head bolts ,make sure you don't put a short one in a long hole.
I did that once , it's amazing how much torque a few threads will hold before they pull out. :doh:
Skifu
Post by Skifu »
It dont really look stripped out.
94 Ford F-150 super cab
knightfire83
Post by knightfire83 »
I agree with the two above. It doesn't look stripped out, a tap may be all you need to clean it up.
However, if it really is stripped out and wont torque down, wouldn't a heli-coil be the correct fix? You wouldn't want the head gasket to eventually start leaking coolant or blow out around the cylinder.
1970 Ford F250 4x4 ~ Sold.
70_F100
Post by 70_F100 »
It looks like you've pulled out the top two threads, probably from using a bolt that's too short.
Make sure you've got the right length bolt, and you shouldn't have any problems.
OldRedFord
70_F100 wrote:It looks like you've pulled out the top two threads, probably from using a bolt that's too short.
Thats what I did. I used the wrong length head bolt for that hole. :oops:
The only damage is to the top few threads. The rest of the threads are undamaged.
Tim
BobbyFord
Post by BobbyFord »
I wouldn't sweat it. Chase the threads with a tap and select the correct length bolt this time :D
