Removal of Passenger Side Exhaust Manifold Shield and Stack
70F250CamperSpecial
Post by 70F250CamperSpecial »
70 F250 360
I am removing the valve covers to check for bent push rods. How do you remove the passenger side heat sheild with the "stack" that goes to the air cleaner housing? :? Specifically can you just remove the "stack"?
Thanks, Rob
70_F100
Re: Removal of Passenger Side Exhaust Manifold Shield and Stack
Post by 70_F100 »
You'll have to remove the nuts that attach the shield to the exhaust manifold.
70F250CamperSpecial
Thanks Guru, I suspected as much.
