352 engine question
- jrsyredneck
352 engine question
i found a 352 block for sale guy doesnt know what its out of do you think it would fit a 1967 f250 with a fe 352 ?is there any diffrences?
- fireguywtc
Re: 352 engine question
All FE blocks are essentialy the same, so it should fit with no changes at all.
Bill
most all of the fe blocks are marked 352 on the front of them. they were that way for awhile. then they were stamped with 501 or backwards 105 in the mid 70's sometime. but the fe/352 blocks can be several bores. the bore size will say exactly what the block is now. then when you add the crank it can be made into what ever size engine you want as long as the bore size will let you go that far. but yes it will fit in your truck.
as far as is the 352 a good engine. well yes and no. the 352 is a good engine but the 390 is a better engine. the 352 block can be bored out to make it into a 352 with the use of a 390 crank rods and pistons.
- convincor
the only real difference was the earlier blocks only had two motor mount holes were the later blocks had 4.
old style
later style
some info on what mount to use here- http://www.fordification.com/forum/view ... 37#p455637
old style
later style
"Still Plays With Trucks"
- jrsyredneck
thanks guys
appriciate the help
