Who has installed a mustang tank???
9yrsmkn
Post by 9yrsmkn »
I have the tank and everything installed. What I am wondering is how is everyone venting there tank? The filler and cap I plan on using is not vented. I have thought about using just a brass nipple and drilling a hole in the back corner of the tank and brazing it in place and running a hose from there. I haven't done anything yet because I haven't figured out the best way to do it. How has everyone else vented there tank?
Dragon
Re: Who has installed a mustang tank???
Post by Dragon »
Get a vented cap.
convincor
Post by convincor »
Dragon wrote:Get a vented cap.
Exactley my plan.
"Still Plays With Trucks"
Calvin Gunter
Post by Calvin Gunter »
Install a barb fitting in the neck and run a vent hose off of it.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
9yrsmkn
Post by 9yrsmkn »
I have another question. What is a safe distance between the gas tank and tailpipe.
Thanks!
convincor
Post by convincor »
as long as there's air space there's no need for concern.
to close and you'll get a rattle.
Dragon
Post by Dragon »
Factory clearances have been less than 1/4 of an inch. The main thing about it beside the rattle by the time the pipe gets to the back it is not hot enough to set the fuel on fire. A friend of mine ran them about 6 inches apart dead straight out of the back of his 66 Stang about 1/4 off the bottom of the tank.
9yrsmkn
Post by 9yrsmkn »
Perfect! I will have no problem with clearance then. I should be able to keep them a couple of inches away without a problem. Thanks For the help!
9yrsmkn
Post by 9yrsmkn »
So I haven't finished the tank vent yet. If I install a barb fitting and run a hose off of it I think I should have a check valve on the end of it that will allow air in but not let fumes out. Does anyone know of a supplier for something like this. That does sound like a good idea right. I have searched a lot on this subject, but have not came up with the best idea yet.
Thanks!
BobbyFord
Post by BobbyFord »
Vent line should be run to a charcoal canister. The best idea is to run a vented cap.
Dragon
Post by Dragon »
Factory charcoal canisters had a check valve.
BobbyFord
Post by BobbyFord »
Dragon wrote:Factory charcoal canisters had a check valve.
Yes, and when the check valve got corroded - no more vent and the truck would die at half tank, until you remove the gas cap. Don't ask me how I know :doh:
None of the Mustangs that I've owned has a charcoal canister, all had vented caps.
9yrsmkn
Post by 9yrsmkn »
I was reading in another site that it was not a good idea to run a nipple with a hose because it would let out to many fumes in a garage. Isn't a vented cap going to let out just as many fumes as a nipple and a hose? I was thinking of using a chain saw style fuel filter on the end of the hose hidden up high to keep debris and bugs from getting in.
I am using a marine style filler in the bed floor. So a vented cap will not work and I am trying to find alternatives.
Thanks!
BobbyFord
Post by BobbyFord »
9yrsmkn wrote:I was reading in another site that it was not a good idea to run a nipple with a hose because it would let out to many fumes in a garage. Isn't a vented cap going to let out just as many fumes as a nipple and a hose?...
My 67 Mustang is in my garage with a vented cap and there are no fumes. Why are you so against running a vented cap?? Your truck HAS a vented cap on it now. Why will a vented cap not work on your set-up?
Here's a link to my Mustang tank install: http://www.fordification.com/forum/view ... =7&t=46022
Dragon
Post by Dragon »
The reason a vented cap does not fill the garage with fumes is, it is not an open vent it allows air to enter and leave the tank only when the tank needs to pull fuel or when expansion from heat means air pressure build in the tank and must escape. It only opens to do this when there is enough pressure. Park over hot asphalt with an under car tank and after a few minutes smell the cap area and it will stink. I have watched the wavy air by a tank on hot days as the fuel cooks.
