Distributor Question
- wildcard
I put in a new dizzy last weekend on my 300-I6. It looks like the rotor is pointing about 3/8" to the left of center of #1. Also the dizzy seems to be pointed more toward the firewall than the one I took out. It runs real smooth at an idle and up to 50 MPH. After that it starts to miss and stutter. I'm going to try to pull it and turn it a little this weekend. Should that fix the missing at higher speeds ?
Re: Distributor Question
as long as the dist is timed right witht he enigne it wil run right. have you been able to verify or check the timing since you put it in yet?
- wildcard
Not yet. Hoping toget to it this weekend.
