Lubrication for vacuum advance plate?
- HOWDY69
When I was messing with the points yesterday it seemed like the advance plate was a little sticky. Is there supposed to be any lube under the plate? I thought mabe silcone spray but there is a lot happening under the cap so I didn't want to putting anything in there that would mess it up.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- DGrant09
Re: Lubrication for vacuum advance plate?
I just googled this and found a pretty good article from Mustang Monthly. They reference the distributor as a loadomatic which I have never heard ours being referenced as, but I imagine the idea is the same. Here's a link.
http://www.mustangmonthly.com/howto/mum ... index.html
Dan
Dan
09", F350, Cabelas, 6.4L
72", F250, CS, 390, 2 WD
- HOWDY69
Thanks...looks like a good article.
- DGrant09
I've bookmarked it also, talks about how to recurve and between that and this site I may try mine.
