68 2wd 360 potentially swapped to 79 4wd
bike5087
Post by bike5087 »
Hello - I have a 68 2wd f250 with a 360, np 435. There is a 79 f250 4wd for sale an hour from me. I looked at it briefly,it has a 400 and a 4 speed. The body isn't that bad, but I love how my 68 looks! Also - its only $800, but the guy says it runs but misses. I'm thinking about offering him $700, then doing a body swap and possibly putting my 360 out of the 68 into the 79 frame.
Some questions:
Is it worth it?
Steering column - do I keep the 79's?
If I were to swap the 360 to the 79's frame and tranny - I'd need a bellhousing and possibly motor mounts?
What else besides the slight frame differences will need to be addressed in the body swap?
Any suggestions?
Re: 68 2wd 360 potentially swapped to 79 4wd
use the 79 4wd column. it is not like a 2wd column. swap over your entire enige and bellhousing. as well as your enigne stands. they might work if you drill the crossmember to accept them.
Hawkrod
Post by Hawkrod »
2WD mounts won't work in a 4WD there is no crossmember to bolt them into on a 4WD. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
bike5087
Post by bike5087 »
Could I possibly find mounts that would work?
duh thanks i wasnt thinking clearly abotu those. yes you can find fe mounts for a 4wd to fit a 79.
