Carb Linkage
OldRedFord
Carb Linkage
Post by OldRedFord »
This is a carb linkage on a dentside F250 CS with a 460. Have any of you seen the longer rod that hooks to the carb? It looks longer then what is on my bump.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Carb Linkage
i think most carbs linkages are going to be slightly different in lenght from the pedal. that is why those rods are adjustable. that eldebrock looks like a 4bbl with the normal rod on it that may have been adjusted out to fit that carb. that rod looks like a stock rod to me.
basketcase0302
Re: Carb Linkage
Post by basketcase0302 »
OldRedFord,
I've got one here that i got from eboy a few years back, (I hope to eliminate the existing "trapeze linkage" on my bump during my build).
IMO the fewer parts the less chance for stuff to break. :2cents:
It seemed longer than the one from my 79' and has an offset bent into it from the factory.
Here's the picture links, the 79'/460 rod:
http://s240.photobucket.com/albums/ff13 ... g&newest=1
My 79' homeade 302 linkage rod, (no I didn't make it/but ran it for several years):
And the 79' 460 intake manifold bracket that holds the cable linkage:
Hope it helps...
edited to add pic links
