electronic ignition conversion
- randyvines
I would like to convert my points to electronic ign. My 67 f100 has a 351w installed by PO any recommendation if so a specific model? not looking for anything special performance wise. Just a good quality/value.
- Ranchero50
Re: electronic ignition conversion
I have one of the Mallory replacement sets in my '68 fairlane in the original distributor. The good, it's a simple kit, three wires, two to the coil, one to a ground. The bad, uses a mallory rotor with the optical window and they are difficult to find sometimes.
Pertronix Ignitor. Fits under the cap and retains a stock look. If you can afford the price jump get the Ignitor II.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- Redcap
Duraspark! Or, use the Duraspark distributor to trigger a MSD 6AL and Blaster SS coil like I did.
- basketcase0302
Randy,
The Pertronix ignition has been in my truck for many years now, no problems at all. The Duraspark is also a proven electronic ignition that's dependable, (I've also ran it for over 20 years now).
Economically and simplicity...I'm stayin' with Pertronix.
Basketcase
Basketcase
- Redcap
I'll be the one guy that has had trouble with Pertronix. Burned up two Ignitor IIs and a regular Ignitor. Same rig, same setup, all wired correctly.
However, lots of guys have great success with them.
- michael69
When I put the pertroix in the 360 I was told that if I used any coil that put out more volts than a regular stock coil it would burn it up in no time.Redcap wrote:I'll be the one guy that has had trouble with Pertronix. Burned up two Ignitor IIs and a regular Ignitor. Same rig, same setup, all wired correctly.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- basketcase0302
michael,
I had to install an external ballast resistor on the 71' Ranchero when we did the install on it last year.
An important part of the pertronix install is to measure the voltage to the distributor.any coil that put out more volts than a regular stock coil it would burn it up in no time.
- michael69
I was just wondering if that was what was happening to Redcap's since he had went thought so many. I have had the sameone on mine for 3 yrs with 40,000 miles and love it. If it went out today I would replace it with another.
Michael69
- ForingaMex
I don't have any experience with any of the other ones but I put the Duraspark on my 390 and it works great. If you are looking for "good quality/value" than my sugestion would be to go with the Duraspark. Lots of info here on that and step by step directions on how to do it.
Jake
Jake
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
- Redcap
Funny part about that is I bought the damn Pertronix coil with the first Ignitor II. After I toasted the second one, I swapped back to my stock coil and killed the third, which was an Ignitor I. Each time, they ran for a little while, but...I'm completely done with 'em.michael69 wrote:When I put the pertroix in the 360 I was told that if I used any coil that put out more volts than a regular stock coil it would burn it up in no time.Redcap wrote:I'll be the one guy that has had trouble with Pertronix. Burned up two Ignitor IIs and a regular Ignitor. Same rig, same setup, all wired correctly.
The Duraspark/6AL works great.
Many choices out there. YOu can alos use the MSD 6 box with the points distributer. The points are only used as a switch withno current andare supposed to last a real long time lke that butI have never tried it. Just another option.
Cheapest way might be the durapsark set up either using the stock box or a HEI 4 pin Module hidden somewhere. The 4 pin takes the place of the dura spark box and is supposed to be able to handle any coil and input voltage with or without a resistor wire in line.
Never used the Pertronics. Heard a lot of good things about them but also know a guy that had one burn up on him using everything that was recommended.
I have used the crane cams point illiminator kit with success at the time but have not heard from the owner in a while now
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
I have a Mallory Hyfire box on my truck and it to only uses the points as a switch. Easy hook up but needs 12 volts to coil at all times to work right. Only have to change points when the rubing block wears out. Puts out a hot spark and has been on my truck for 20 years.
- randyvines
Kind of a novice question, but...
when getting ready to order the system (I am looking at the Ignitor II) how do you tell the difference from single point, dual point mechanical advance or dual point vacuum advance? I really want to ensure I order the correct item. I do not know what the year of 351w in my 67 is.
- Redcap
randyvines wrote:Kind of a novice question, but...
The number of points under the distributor cap. 351w was never offered factory in a '67.
