1980 F350 460 Swap
RustyBolts
1980 F350 460 Swap
Post by RustyBolts »
I realize my truck is a bit newer than most on this site, but I was hoping that there is somebody here that can help me. I have a 1980 F350 that originally had a 400 in it. When it blew, my Grandpa rebuilt a 460 to put in there. The thing that stopped him was motor mounts. I want to get this truck back together and running so bad i can taste it! I saw in the Summit catalog where Trans-Dapt has "complete" motor mounts for $111.95, but, I'm a bit leary of them. In that case, what all do I need to change out, in order to make my 460 rest comfortably in the 400's place, and basically make it a "factory" job? For the record, the 460 was not available in these trucks from 1980-1982.
papabug71
Re: 1980 F350 460 Swap
Post by papabug71 »
The first thing that comes to mind is towers & mounts. The 400 & 460 have the same bell housing bolt pattern, so your tranny "should" bolt up, as long as the flywheel matches your specific transmission.
If it was me, I would go to a bone yard/salvage & find a 83+ truck with the 460 & get the engine towers from it. Take out your 400 towers & swap in the 460's.
Then it would be as easy as going to Autozone & getting a set of motor mounts for a 83 F-350 with a 460
:2cents:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
RustyBolts
Do you know of any place that has the towers available? I've scoured all of our local junkyards, there are several 80-97 trucks there, but none of them have/had a 460 in them. :help:
papabug71
Post by papabug71 »
E bay or craigslist would be my next stop. I would also call around to the junkyards around your area. Even if you have to drive an hour or so to get to them.
Matt
Mine since 5/7/'94
RustyBolts
papabug71 wrote:E bay or craigslist would be my next stop. I would also call around to the junkyards around your area. Even if you have to drive an hour or so to get to them.
I've called all the junkyards within a 1-1/2 hr drive from my house. nada, zip, zero,zilch. I'm heading to eBay next.
70_F100
Post by 70_F100 »
RustyBolts wrote:Right now it'll cost me more to get them here, than it will to buy them. We'll see. Thanks again :thup:
That's not unusual. Shipping can be pricey.
The thing is, this has all six pieces, which you will definitely need, and they're factory.
Even with shipping, that's still probably less than it will cost to make phone calls and drive a couple of hours to pick up a set that probably won't be as nice as these look.
RustyBolts
Yep, you're exactly right. I'm watching them right now, but there's still 3 and a half days left on them. I'm definitely gonna try bidding on them when they get closer to deadline. Hopefully I'll walk away with them! :pray: Wish me luck!
Caseys71
Post by Caseys71 »
Good Luck :thup:
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
RustyBolts
Thanks. Spread the word, and keep sending the good juju my way, please. :D :fr:
