I chose a new machine shop that the local racers seem to like. They are a lot more knowledgeable than the previous shop and have 'blueprinted' the block for me with a fresh align hone on the cam and crank, resized the rods both ends, balance the crankshaft internally as well as the rest of the rotating assembly. During the first build the machine shop I used drilled the flex plate and harmonic balancer as a shortcut to balance it, I had that undone and the crank properly balanced. Here is the block fresh from the machine shop:
Large
I decided to have the common oiling mods I read about done on the block. Here you can see the front bearing oil hole has been chamfered to meet up with the bearing:
Large
I also had the main oil feed enlarged to 7/16":
Large
Now I put together the piston/rod assemblies:
Large
I am using Silvolite 1131 pistons .030 over. The 1131 flat tops have 8cc of valve relief. The first rebuild was with 1130's and I didn't calc the compression ratio, I assumed the catalog value of 9.5:1 was accurate. Turns out that it's pretty far off. The 1130's with 19cc of dish/relief come out to 8.1:1 with an .032" deck clearance (measured), .060 compressed gasket, 72CC heads, a 4.080 bore and a 4.40" bore gasket. The 1131s come out to 8.9:1 with the same installation which is right on target for what I want. This pic shows the 1130 Silvolite (dished), 1131 Silvolite, and the original 390 ford piston that was in the 360 from the factory.
Large
Got the crank installed.
Large
The cam and timing chain installed too. I am using an adjustable billet double roller timing set. Set the cam at 2 degrees advanced. The cam is a Comp Cams Xtreme Energy grind XE256H.
http://winnfamily.smugmug.com/photos/506206942_Y8Dmb-XL.jpg
Painted some sheet metal, all old ford blue.
Large
The heads are at the machine shop, so once I get those I can proceed with the build up. Will post more photos.
