turning flywheel
- 67RED
turning flywheel
hi guys just removed clutch today. that was a job. was wondering can you have the flywheel turned seems to be a couple of grooves in it. any info appreicated
- heep70
re: turning flywheel
Yes and check to see if the starter ring needs to be flipped while you have it out.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- willowbilly3
Any automotive machine shop should be able to resurface the flywheel. We have discussed this before and I know flipping the ring gear has been done successfully by lots of guys. I only tried it once, on a 428 I had in a 69 highboy. The starter would not disengage. I pulled it back apart and found that the ring gear was cut on a bit of a bevel, it would only work one way.
Another bit of advice; Do not be surprised if your clutch adjusting rod isn't long enough when you get it back together. If the flywheel has been resurfaced a couple times it moves the whole clutch assembly foreword. That combined with the sloppy tolerances of remanufactured clutch discs may cause this problem to occur. Just fabricate a longer adjusting bolt.
- 67RED
hi guys got the flywheel resurfaced today. now rain coming in no shop to work in. $25.00 to get it done guess that wasn't to bad.hurt my back taking transmission out. pulled a muscle i think. got a guy coming out thursday gonna tow it to his shop and reinstall it. hope to be back on the road soon.
- NATHANHASNORIDE
$25.00 isn't to bad our local machine shop will do it for $15.00 if you let him do about $350.00 worth of work to your heads
.My bro-in-law got his heads ported,polished,and 15 angle valve job and all that good stuff and he resurfaced his for $15.00 so I assume he will do that for everyone who spends a nice chunk of change.
Goodluck and hope you have that thing on the road again soon!
-Nathan-
-Nathan-
NathaN
I'd push a FORD before I'd ever drive a CHEVY!!!!
- 67RED
got 67red back on the road. but with that new clutch almost had to learn to drive i again
steve
Life is 90% how you take it10% what you make it
