Rear Questions
- Ditchdigger
Rear Questions
What is the difference between a limited slip and a traction lock rear. I have a open rear now with who knows what gear ratio, since someone has changed them before and didn't put a tag on. Just wondering which way I need to go, as I want to run 3.00 to 3.08 gears behind a mild 460 and C6 trans with a firm shift kit. ( new valve body )
- morganater
re: Rear Questions
A posi is a much much more involved installation than a straight locker. A posi will allow both wheels power while turning, through the use of plates and clutches and all sorts of complicated stuff
. A locker will only give both wheels power in a straight line. Either are pretty effective at putting power down. My 460/C6 in a SWB 67 with an open rear end is rediculous. I cant hook up anywhere... Go with a locker or don't even swap in the extra power. The torque of the 460 will allow you to sit there and burn forever: bad. 3.08 or so sounds really tall though.... Might be losing a lot of low end grunt, depending on what size tires you are using?
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
- heep70
re: Rear Questions
The installation is the same on both a clutched locker and a true locking rearend. The clutched locker (Power-loc or Trac-loc) use clutch packs and allow slip to happen while not under torque (depending on how they are set up). The Trac-loc is more forgiving then the Power-loc. If you want solid all the time hook-up. Lockers like Detroit would be the way to go, but that is for thr real serious power freaks. If you are looking for something that is mild go with a trac-loc, Power-loc or even a True-trac. Check out this website for more in depth info.
http://www.ring-pinion.com/content/tech ... sp?pid=128
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- Ditchdigger
re: Rear Questions
Has anyone used the powertrax before? How do you think this will work?http://www.powertrax.com/noslip.html
- heep70
re: Rear Questions
I haven't but a couple buddies of mine have and really liked them. The only fear I have is that I have seen the Lockrites strip the teeth when used for 4xing. That was only one time. I have installed a Lockrite is a D60 before and it was really easy and I ran into no problems with it. Go on line and do a search for reviews on the Powertrax.
http://www.4x4wire.com/reviews/no-slip/
Greg
- morganater
re: Rear Questions
I am planning on getting a lock-right Powertrax for my 9" sooner or later. There is a PDF walkthrough of the install into a 9inch floatin around on the net somewhere also.
reppin' AK
reppin' AK
