Rear End Swap
Rear End Swap
Greetings everyone, I have a 1971 Ford F-100. I put in a 390 out of a 1978 F-150 (yes in 78' they had 390's in commercial trucks). The guy i bought the truck from had a little 302 and a car rear end in for speed, not power. Now I have the rear end from the 78' still. would it be better to have a new driveshaft made, or swap the rear end?
Thanks, Tyler
Thanks, Tyler
re: Rear End Swap
That rearend won't fit. The spring pads are farther apart on those truck's rearends. The third member will fit your existing housing, but it's probably set up for 31-spline axles (as opposed to 28-spline axles in yours now), and the longer axles won't fit your current housing.
You'd either have to move the spring pads to get that rearend assembly in there, or try to find some fairly-rare 31-spline axles that'll fit your existing narrower housing.
- pat67shorty
re: Rear End Swap
On the '67-'72 trucks the rear track width is narrower than the front....that is, the rear wheels don't track directly behind the front. In '73 when the rear frame rails on most trucks was widened out 4", the rearends also became 4" wider, which brings the rear wheels out to track directly behind the fronts.
- binder56jd
re: Rear End Swap
what was the reason behind the narrow rear?
now serving #235
now serving #235
- SmokeyBear
Re: re: Rear End Swap
They aren't married yet.binder56jd wrote:what was the reason behind the narrow rear?
Historically older vehicles just had a narrower frame. As technology caught up the frames got wider to stabilize the vehicle.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- ToughOldFord
- binder56jd
re: Rear End Swap
now serving #235
now serving #235
