shrilling noise
rdmac
shrilling noise
Post by rdmac »
i have a weird noise in my 71 302 auto. you can faintly hear it taking off, but not bad. you get to 50 to 60 mph and if you let off gas it makes the most shrilling noise i ever heard. if you keep giving it gas, it doesn't do it. you can let off gas and it will stop. it sounds like its somewhere around the tranny or end of engine. the engine has 3500 miles since rebuild and guy i bought it from said it has been doing it all the time since. do anyone have any ideas. its driving me nuts. i hope i have explained this good enough fro someone to help me. thanks
rdm
70 f100 lwb 302 3speed/overdrive
71 f100 swb 302 auto
ToughOldFord
re: shrilling noise
Post by ToughOldFord »
Check/lube/replace your u joints.
rdmac
re: shrilling noise
Post by rdmac »
i have checked rearend grease and its ok. haven't checked driveshaft. there is no vibration so i didn't think it would be it drive shaft. will check it tomorrow. thanks
rdm
ToughOldFord
re: shrilling noise
If your u joints go dry they'll squeal, but they won't vibrate until the bearings get chewed up. Greasing them will buy you some time, but when they squeal that usually means they're on their way to failure.
rdmac
re: shrilling noise
Post by rdmac »
you guys are so smart, you need to start charging for info. i greased my u joints and most of my noise went away. you really have to play with gas pedal to make it squeal. i guess i will put in new joints soon. have a pinon seal leaking anyway, so will have driveshaft out. good time to do it. thanks again for info. i just love this site. thanks guys and keith.
rdm
