shaking
shaking
i got 1970 f100 and it has a 3spd manual trany and every time i let the clutch out the whole back half of the truck shakes but it onley does it when i give it gas. would that be the clutch or the rear wheel bearings.
- mrung0wa
re: shaking
Sounds like the clutch/tranny to me!
What kind of noise do you hear when this happens?
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
re: shaking
Maybe a carrier bearing. I had that happen before. vibrates like mad.
re: shaking
a real fast shuddering
re: shaking
CK the driveline. U-joints, and make sure the U-bolts on the rear axle
are tight. If you have a jack and stands you can jack up the rear axle
and put stands under it and run it in gear to see whats going on. Or pull
the driveline out and CK the U-joints to see which one is binding.
- binder56jd
re: shaking
my old 72 w/3 speed and 3.25 gears had new clutch and everything on back- it would always shudder at take off-the gears were just to high for the 3 speed- have seen newer fords w/ same problem-jd
now serving #235
now serving #235
- 72hiboy4x4
I figured it was the higher gears that caused it.
re: shaking
or could it be the transmishion mounts gone soft
re: shaking
I am going to put a new clutch,u joints,rear wheel bearings in any way if it dont stop then i guess i got a serious problem
My 71 f100 always did that when it was still a straight drive, until I went to a diaphram type pressure plate. It could also be caused by the flywheel being glazed over. It is always a good idea to have your flywheel surfaced when installing a new clutch kit.
I went to an automatic and stopped all the shaking. lo
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
re: shaking
When I have seen this in the past it was clutch, pressure plate and throw out bearing.
Bobby
Bobby
re: shaking
I have that problem often in my trucks, normally its because I'm hard on the clutch and I rip the disks damper springs apart. First thing stop dumping the clutch at lights
The 10" clutch don't like this.
then replace the disk I'm so aggressive that now I just use autowecker disks (on the old small diameter clutches)
cause even new ones only last 1mo.
Only once was it from the drive shaft it self.
WHAT ?
- Heavenlyfire
I'm with bwc302 on this one. Check out the throw out bearing. I had that same issue on a hot rod that I use to have and that was it. If you are going through clutch plates then you may want to go to Napa or some other big name part dealer and have them line you up with a performance disk that is a little thicker and tougher.
I looked around for months. And I didn't come up with any performance clutch for the old small diameter clutch set , later I got mad and use one for a 460 or something in conjunction with a new used large flywheel & bell housing. It was bigger diameter and I was able to get a performance clutch set.Heavenlyfire wrote:I'm with bwc302 on this one. Check out the throw out bearing. I had that same issue on a hot rod that I use to have and that was it. If you are going through clutch plates then you may want to go to Napa or some other big name part dealer and have them line you up with a performance disk that is a little thicker and tougher.
WHAT ?
