FMX to C4 swap
Killa67
FMX to C4 swap
Post by Killa67 »
I have a FMX behind a 92 model Crown Vic 5.0 motor changed to carb. I am wanting to put a C4 in the truck. Will the crossmember work or will I have to do some custom fab work? Will the driveshaft also fit? The truck is a 67 F100 shortbed. I am about to jump in and take a serious journey to make this truck a turbocharged monster!!!
Go to sleep at 9:59 back on tha grind at 10:00.
Jake11
re: FMX to C4 swap
Post by Jake11 »
The FMX is a stronger tranny than a C4. Why change it?
Killa67
Re: re: FMX to C4 swap
Post by Killa67 »
Jake11 wrote:The FMX is a stronger tranny than a C4. Why change it?
The C4 is a racing trans with billet servos ,manual reverse valvebody with trans brake,and rollarized planetaries,with 300m Vasco input shafts and JW SFI approved bellhousing. Also I have a custom 8" stall converter setup for the turbp kit I have.
Jake11
re: FMX to C4 swap
Post by Jake11 »
Oh, just askin. :)
390Nut
re: FMX to C4 swap
Post by 390Nut »
The C4 is also quite a bit lighter, if what I've been told is true.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!" :thup:
gonzalo medina
re: FMX to C4 swap
Post by gonzalo medina »
So the fmx is better then the c4. I heard by a hardcore mustang fan that the fmx was an experimental transmission that really sucked. And I have even heard a bunch of bad stuff about the c4's????? Someone school me please
c6 is best. i had c4 in my falcon. its is made for smaller applications. yes i have also heard the fmx is junk.
mrung0wa
re: FMX to C4 swap
Post by mrung0wa »
Many Moons ago, When I was still in my Youth I owned a 75 F100 302 with an FMX. I decided that I wanted to build up a 351Cleveland 2V that I had sitting in a 72 Ranchero.
I did not realize at the time that I had an FMX so I had the C4 from the ranchero Built up Extra Heavy Duty. When I installed it in the Truck I had to fabricate a Tranny mount in order to adapt it to the crossmember. Next I had to Have a shorter driveshaft custom made. That cost me a chunk of money and alot of extra downtime plus labor (mine) when all I had to do was to buy a C6 core and have it built up. That would of saved me a lot of unwanted and needed drama.
Live and Learn and as long as you don't repeat your mistakes Experience is the best teacher...
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
Killa67
Post by Killa67 »
mrung0wa wrote:Many Moons ago, When I was still in my Youth I owned a 75 F100 302 with an FMX. I decided that I wanted to build up a 351Cleveland 2V that I had sitting in a 72 Ranchero.
Lawrence 8)
Thanks, for the info I will be doing the install this weekend I might have to fabricate a crossmember for the rear to accomodate for the single 3-1/2" exhaust off the downpipe. I will post up some pics this weekend. Thanks guys!
