Oil Pan Scavenger Hunt Find - What the hell are these?
- SoCalExile
I'm hoping these are pieces of an old timing set, what say you?
Re: Oil Pan Scavenger Hunt Find - What the hell are these?
I say wash them with soap and water (if nothing else) and get a better look at 'em, then decide? ;)SoCalExile wrote:I'm hoping these are pieces of an old timing set, what say you?
Butthead in AZ
They are the nylon teeth(makes the gear quieter) of an original linkbelt timing gear.
I would say that motor needs a timing set, to me it looks like plastic that used to be on the upper timing gear. see how much play there is in the timing chain, ive found the same thing in a pan a time or two and it was the upper gear sheading its plastic. Be sure to clean the screen on the pick up tube also because ive found pieces on the screen too.
- SoCalExile
Yeah I yanked the timing cover and oil pan. I bought a Comp Cam timing set to fix the 4* of advance that Ford put in the stock cam.hazelnut wrote:I would say that motor needs a timing set, to me it looks like plastic that used to be on the upper timing gear. see how much play there is in the timing chain, ive found the same thing in a pan a time or two and it was the upper gear sheading its plastic. Be sure to clean the screen on the pick up tube also because ive found pieces on the screen too.
However, I found a nasty surprise that's a little more serious than the disintegrated gear - a nice ring sheared into the inner side of the timing cover:
The timing set did have some serious slack in it:
There is another ring worn into the other side, where the water pump impeller might be.
So...seeing this, what would you guys recommend I do?
Cool thread! :)
Please keep tearing it apart and posting pictures. ;)
Butthead in AZ
Butthead in AZ
Put a roller chain back in.
- SoCalExile
This one came out kinda artsy:Alvin in AZ wrote:Cool thread!
Butthead in AZ
More:
well you can see the damge left behid fromt he old gear and chain going bad. the old teeth in the oil pan and i guess the timing cover got ate up soem how whent he chain went bad.
- ForingaMex
The plastic pieces are from a cam gear but not from the one that is on there now. It has been replaced and the wear on the cover might be from before the chain and gears where replaced. I looks like the fuel pump excentric doesn't have any wear on it.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
- 70_F100
You need to double-check to make sure there's no wear on the camshaft thrust plate.
That's not an oil leak
Cool one Mex. :)ForingaMex wrote: The plastic pieces are from a cam gear but not from the one that is on there now.
Was wondering about that, couldn't see where they'd be from looking at the gears. :)
Alvin in AZ
now wait. why does the eccentric look like its doubled up? it should only be a single cup not a double.
- 68muscletruck
yup those are definitely the nylon teeth off the original timing set... my guess is if someone that owned it previous to you came in and did a timing set, they didn't bother to drop the pan and get any of that debris out
just found the same deal on my 360 except most of the nylon was still on the gear cause it was the original timing set
As far as the fuel pump eccentric that is a 1 piece unit.. I don't know FE's but on a small block the early blocks had a one piece and somewhere around 69 to 71 or so they went to a 2 piece I think to quiet it down a little.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
