Sputtering, bucking at 70 mph uphill
- Winslow
New member. I have a '70 F100 (302 V8, auto. trans.) that runs fine except when going up over mountain passes, etc. where the speed limit is 70 mph. Sometimes, the slope causes me to begin to lose speed and so I give it more gas. I think at slower speeds, it would downshift from 3rd to 2nd, but according to the manual, it won't downshift over 65 mph. As I give it more gas, it starts to sputter, buck and lurch. At that point, it seems like it's flooded or something, because even slowing down doesn't solve the problem for some time. My mechanic put in a new fuel pump (which includes the filter) but the problem persists. Seems like I should be able to drive in all conditions at the speed limit, but maybe I need to hold it to 60 or 65. Preparing for a trip that takes me over the mountains and hope to avoid this problem. Any thoughts apreciated.
- Wes
Re: Sputtering, bucking at 70 mph uphill
what is the elevation of this pass. Your carb has a fixed air fuel ratio. You may be experiencing to much fuel and not enough air. Not much you can do to fix this unless you live 4000 above sea level then you can jet the carb for higher elevations. It may be possible to compromise on jetting. You might want to check your secondary ignition, It's possible the spark is breaking down under the sever load.
good luck
good luck
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- mrtleavitt
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
- Winslow
Thanks very much for the replies. I have had this problem on the steeper sections of highway approaching Snoqualmie Pass, WA (3,022 ft.) and also on the steep climb from Vantage, WA (663 ft.) up to George, WA (1,227ft.). I will follow up with my mechanic on your thoughts.
Winslow
Winslow
Not the carb jetting at that altitude. The fact the engine got hotter with all that wide open throttle then has to cool down to run right again. With wide open throttle you lost vacuum advance. All that load and heat probably hit you one place you did not expect,the coil. Most carbs will climb to 9000 or more before they get sick. I am a Colorado native by linage and flatlanders could get to 9000 or 10,000 before the carbs made them sick.
I drive at 5500 feet all the time and my holley is 2 jets down from 72 to 70 now and I am still a hair on this side of lean. North to Santa Fe is 7500 with about 8500 ft pass in the way and East is almost 9000 and West is 8000 from this valley. So I don't get too much worse treatment. My 69 f350 360 when loaded to 8000 gvw with stock coil and Accel points eliminator did that one after noon coming south. I got done with that job and put an autolite reman carb on then did it the next day, same problem. I did have a bad carb before and it did it again. I stopped and picked up a 8140 Accel coil and it went away the 3rd and final day hauling that load of tools south to home. Mornings were cold afternoons were almost 100.
Take a hot air gun and set you idle high with the truck parked and heat your coil up and see if it gets sick.
- mrtleavitt
Ya that's not enough elevation to give you those problems due to jetting. I agree with dragon, check for electronic problems showing themselves when things get hot.
- Winslow
Thanks so much. Will check that out.
Winslow
Winslow
- Winslow
Thought I would report back in case anyone is curious about the outcome. Dragon was right. Had a new coil put in this week. Took the truck up to the top of Snoqualmie Pass yesterday at 70 mph as a test. No problems.
Thanks again,
Winslow
Thanks again,
Winslow
No problem
