Valvetrain Geometry
OldRedFord
Valvetrain Geometry
Post by OldRedFord »
I set up to check my valvetrain geometry this afternoon.
I am using the factory stamped steel rockers.
Wondered what you all thought.
Intake
Exhaust
Valve spring with lifter on the nose of the cam.
I used a factory push rod and a solid lifter. I had wondered if the factory push rods would be short with a bigger then stock cam, but didn't mill the heads or the block deck any.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
BobbyFord
Re: Valvetrain Geometry
Post by BobbyFord »
It's hard to tell from the picture, but the pushrod looks to be slightly on the long side. A tiny portion of that will go away with lifter preload (assuming that you have a hydraulic camshaft).
71PA_Highboy
Post by 71PA_Highboy »
Looks like the valve isn't rotating as it should be either...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
OldRedFord
I will be using a hydraulic camshaft. I also put the head on the wrong side if that makes any difference.
Tim
