no exhaust gasket will it leak
if i replace the passenger side exhaust manifold without a gasket will it leak? no planing off of the head or manifold. just remove one and botl the other one on. the drivers side seams ok without one right now. i am hoping i can do it without having to buy gaskets for it. will it leak in the long run? say a year from now? or 6 months from now.
Re: no exhaust gasket will it leak
Impossible to say.
IF everything is flat, surfaces are in good condition and the bolts are properly tightened it will not leak... Thats a lot of "If" though...
- Ranchero50
Put some permatx ultra rtv on and it'll hold up for a good long time.
If you put RTV on it I would just worry about it burning up because of how hot that area gets.
Justin
http://www.fordification.com/forum/view ... 22&t=47482
http://s976.photobucket.com/home/bb429power/allalbums go to both of the albums.
1967 Ford F100 longbed with a 466 500+hp/600+ft-lbs (mine)
1969 Mercury Cougar xr7 with a 351w (dads, I helped alot)
1970 Ford Maverick with a 302 (became our drag car)
1986 f150 5.0 (my DD)
"Many can argue, but it takes a real man to apologize."-Me
- AlleyCat
There is an RTV made for manifolds. I've used it in the past and it does work.
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
- Doug F
I learned long ago that (at least in the 60s) Ford didn't use exhaust manifold gaskets, from the factory.
At least my info was from the 64 T-bird that I grew up with and my 67 Mustang.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
- knightfire83
I always use this in addition to exhaust gaskets on manifolds or headers. Works great on collectors too, it stays pliable for years on end and works great.... Absolutely no leaks, should work out great in your application.
About $5-$6 at any auto parts store.
1970 Ford F250 4x4 ~ Sold.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
IHATE RTV and even I have some of that...oldschoolrods wrote:is great stuff, use it on just about anything. i worked on a isuzu that speced that instead of gaskets for some stuff
Here is my Isuzu tip of the day...
If your friend wants you to help put an engine in a 3.4l DOHC Trooper...however much he wants to pay you is not enough...
- FreakysFords
DItto, I've even had to reuse old donuts on jobs that had to leave same day, and none in stock at local's. a nice little coating and off ya go.
Neighbor's .040 over, wild cammed 454 has nothing but that as header gaskets and has been fine for 2 yrs now. We're in the process of building his second 454 atm since his truck with current engine got beat by a ratty looking old 69 F100 with a "stock" 4v 390.
hahaha, the Isuzu i worked on was an industrial diesel engine - very simple. I should point out the most common place i use it is for cooling system stuff, and have not tried it on exhaust.DuckRyder wrote:IHATE RTV and even I have some of that...oldschoolrods wrote:is great stuff, use it on just about anything. i worked on a isuzu that speced that instead of gaskets for some stuff
pat
- sideoilerfe
Absolutely. I did my 390 in 1997 and had the manifolds machined to match the head and used no gaskets. In 1999, the drivers side manifold cracked all the way in half. I simply got another manifold, had it machined and bolted it on without a gasket. It still doesn't leak.DuckRyder wrote:
Fordman, I would say if the other side is leak free you'll probably be OK but a lot of IF's! I would machine the manifold then give it a shot.
- Dirty Offio
I know a chebbie guy that never uses exhaust manifold gaskets..never seems to have any leaks either.
On the Permatex Ultra Copper, the same guy resused the HEAD GASKETS! Just gave them a thin coat of that stuff, and slapped them on. Damnedest thing I ever saw. That motor ran strong for an entire season in the mud. Oh, before everyone thinks the guy is a total whack job, a friend of ours was stuck out in the middle of the swamp. The only truck that had a prayer of getting into him and getting him out was The Frog, and the engine had a cracked head (SBC). Chuck peeled the heads off and slapped on another set, but did not have the $$ for a set of gaskets. So he coppered them and went out to rescue our buddy. It only had to hold for a day. ran it for about 6 months.
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
doug the factory did use the metal type gasket that had the flange thing on it that kind of went over the sparkplugs. i think i'm goignt o go with nothing as a gasket. for the time being. i don't like the idea of rtv or that copper stuff. i don't know why it just doesn't seem like it would work. maybe it does i don't know.
- ximy
I've run stock manifolds to heads without gaskets.. no warp.. no leak.
1967 f250 428
