good mourning,
This mourning i got a call from my twin brother asking me a question about the serpentine belt on his truck.... he says for a while, since he replace the belt in his truck the belt has been rubbing on another part of his belt...
here is the setup a 1993 chevy with a 350 i be leave. he says the belt tensiner seems to be forcing his belt to rub on another part of his belt. i told him he had the wrong size belt on there but then again i wasn't sure. This mourning he replaced the tensioner and it is still doing this any ideas
nick
any idea on serpintine belt
Re: any idea on serpentine belt
The tensioner should have an arrow or other mark on it that points to a scale. When the arrow is outside of the scale the belt has stretched and requires replacement. If a new belt places the arrow outside of the scale it is not the correct belt.
- iamthewreckingcrew
Re: any idea on serpintine belt
Had a GF once who had a "mechanic" work on her car. He must have put the wrong replacement belt on. Couldn't figure out why it kept chewing up belts. I looked at it and found out that the belt that was last on it was the wrong one (too long), so he moved the position of the tensioner to take up the slack. That put everything out of whack and the belt was burning up because it was rubbing on an accessory bracket.
Most vehicles have the belt routing diagrams under the hood.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
Sounds like they put the belt on wrong.there should be a dieagram( not spell right) under the hood if not find a repair manual.Those belts can be a pain on put on.I have put on a couple he wrong and they well go on several ways
Dean Gray
Dean Gray
Found out my brother is mechanicly inclined and put a belt with AC on his truck that didnt have AC
- ForingaMex
I don't think he is. If he was, than I think he would have noticed that it was the wrong belt.
Jake
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
- Redcap
Nickabocker wrote:Found out my brother is mechanicly inclined and put a belt with AC on his truck that didnt have AC
