date plate just below oil filter
72Highboy
Post by 72Highboy »
Hey there guys I was looking at info on FE engines and came across this website http://www.mustangandfords.com/techarti ... index.html.
It had some good info on FE engines and many things that are new to me because this is my first FE. :lol: I have a couple questions, but I am just sticking with the one that is the easiest. Well after reading this I went out to my truck and started cleaning the date plate off. This is what I came across, I have tried to figured out how to decode it but kept scrathing my head :hmm:. I hope this picture is good I will take another and post it if this one isn't clear to those who help. What else stumps me is the lettering above the plate. :dk:
All advice and input is appreciated :thup:
Joshua
aka Young Gun 8) :drive:
FE - Famous Engine
U.S. Army Veteran/11B
DGrant09
Re: date plate just below oil filter
Post by DGrant09 »
I have one also that I never figured out, but my block is stamped SPECIAL. I guess the Ford folks knew where it was going to end up and built a Special one just for me. One that could withstand all of my mistakes and learning! :D
09", F350, Cabelas, 6.4L
72", F250, CS, 390, 2 WD
72Highboy
Post by 72Highboy »
DGrant09 wrote:I have one also that I never figured out, but my block is stamped SPECIAL. I guess the Ford folks knew where it was going to end up and built a Special one just for me. One that could withstand all of my mistakes and learning! :D
:lol: :yip: Ha Ha thats a good one,Same here just a Young Gun still learning about these FE so cheers to that :burp: :thup: what is the code on yours, is it any close to mine? :pray:
I keep thinking to myself how cool it would be if mine is a special engine. Then I would definitly have one of a kind truck in EP Texas. I think if my mind recalls right :hmm: when I was replacing my clutch, flywheel, and trans I have a block that I can put hydralic lifters in. :D
Joshua
FE - Famous Engine
DGrant09
Post by DGrant09 »
From the sounds of it you have an advantage - age.. You have a lot more time to learn! I've killed to many brain cells to remember my own home phone #!
I'll be checking my date stamps on the block tomorrow for Crower Cams. I'll check around the filter area and see what we come up with.
knightfire83
Post by knightfire83 »
Hawkrod has good info on this post: http://www.fordification.com/forum/view ... =3&t=46762
By his information, the W1 would indicate that your block was cast on the West line, 1st shift.
1970 Ford F250 4x4 ~ Sold.
BobbyFord
Post by BobbyFord »
I saw a post on an engine website that said SPEC or SPECIAL means that it was a not yet finalized casting change.
72Highboy
Post by 72Highboy »
Thanks Ill see if he can help out, Thats cool that they made special blocks but bad if it needs different parts.
Joshua
FE - Famous Engine
