My truck dies at stop signs also. I have messed with the carb and no good has come from it. I am going to rebuild, but want to know what a determining factor would be for just getting a new one? I think the choke is screwy. and if I was turning the proper nut, then the idle is screwy too. how concerned should a guy be over brittle plastic and pitted metal when considering a rebuild or replacement?
Thanks,
Steve
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Hey 72bumbee. How long has the carb been on the truck? If it has been many years, it might not be a bad idea. I think we figured you have the 2100 autolite from the other post. I just rebuilt mine not too long ago and it was pretty easy for my first time doing it. I think I paid like $12 for my rebuild kit at Schucks.
Troy
the time to get a new carb is when the old one has a crack in it soemplace or the throttle plate bushings are worn out and need replaced. or the carb is broken some how or maybe its warped on the bottom.
