Oil pressure questions and concerns.
- flyboy71
Re: Oil pressure questions and concerns.
I see you made it home ok. No issues with the breathers? You must have been taking it easy leaving here, but I could hear you all the way across town.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
Ya I took it easy. It's that loud huh? I know it is on the louder side but it doesn't seem to be that loud to me since I am half deaf LOL. I am debating pulling the motor again just so I can measure the clearances. I am pretty sure it is definitely on the looser side.
The cam that was originally in it was 279 @ 50 duration and .692 lift so they had to of planned on spinning it to 7,500 - 8,000 rpm. I am trying to avoid pulling the motor again but if it is what I need to do to make sure it is right then that's what I will have to do.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
