TRUCK DIES AT STOPS
LUVMY69FORD250RANGER
TRUCK DIES AT STOPS
Post by LUVMY69FORD250RANGER »
weird im cruising along and it dies at stops?? fuel?
THANKS
Re: TRUCK DIES AT STOPS
does it start right back up easily?
willowbilly3
Post by willowbilly3 »
That could be a hundred different things. More information, lots more.
Jake11
Post by Jake11 »
Try adjusting the idle.
hotrod ford
Post by hotrod ford »
willowbilly3 wrote:That could be a hundred different things. More information, lots more.
:yt: : fuel pump, carb, clogged filter, fuel lines, not enough air, idle adjustment and much much more.
Joshpow
Post by Joshpow »
I had the same problem and it turned out to be a vacuum cap off. The cap for the hookup for power brakes that I don't have popped off and it sucked too much air. As mentioned before, several things could cause this. For vacuum leaks, listen for a hissing sound under the hood.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
blumule
Post by blumule »
check your ignition switch.
YES IT USUALLY STARTS RIGHT AWAY
THANKS
ok lets check the ignition switch. can you wiggle the switch up and down without turning it while its running and get it to cut out? if yes replace switch. if no it is a different problem maybe a carb adjustment is in order.
willowbilly3
Joshpow wrote:I had the same problem and it turned out to be a vacuum cap off. The cap for the hookup for power brakes that I don't have popped off and it sucked too much air. As mentioned before, several things could cause this. For vacuum leaks, listen for a hissing sound under the hood.
:yt:
If I was guessing that would be my first. Definitely check all the bases before attacking the carb, carb settings generally don't just change or drift off by themselves.
blumule
Post by blumule »
what did you find out about your truck?
willowbilly3
I also thought of another thing, my 390 doesn't like some of the 10% alky and won't idle if I use it. If I use Sinclair 10%, I end up heel and toeing it to keep it running at stops.
Dragon
Post by Dragon »
loose wires under the hood. Coil to switch push on terminal or coil to dizzy. I had the power to the vehicle drop out and the cause was a taped over wire splice near the starter solenoid.
