I have a 360 v8 in a 1968 F100.
What years, Ford models, and engine sizes share thids radiator. The reason I ask is, can i take a 197x radiator from a Bronco and use it? How about a different vehicle? engine? etc....
thanks in advanced.
question for radiator gurus.
- 03rangerxlt
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
- 03rangerxlt
re: question for radiator gurus.
Bump
I need to find a radiator on a budget soon-ish!
-John
you can use one out of a econoline van right up to the 90's if you cut down the side mounts on the rad.
I use a 351w 89 econoline large core rad in my truck it looks the same but I did need to re drill & cut about 1" off both sides of the rads mount to clear the trucks rad support webbing.
if the rads bungs are smaller than the hose I just use a old peace of rad hose as a resize spacer.
WHAT ?
- 03rangerxlt
Aight, I'll use that as a last ditch thing. I need a radiator I can easily order and have shipped to my mechanic so he can drop it in if possible though. If it comes to that, I will just order it,snatch my old radiator out of the truck, and get themto match, and then drop the mod'ed one off for install.
-John
I did the same thing i used a bigger radiator out of a van in my 70 and i had to also cut the sides to fit. I like the bigger radiator and it has coller lines for my tranny
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- 390F100
Not much of a radiator guru but I bought an all aluminum radiator for my 68 f100 for 275.00. Considering all of the other aluminum radiators I have seen on jegs, summit, etc. this was a smoking deal. If you want one, or if anyone wants one here let me know and I can order them from my supplier and ship them to your locations.
390f100
390f100
