I was wondering if for our clutch linkages if you could but bearing in those areas instead of the device that is in there now.
The area I am talking about is on either side of the equalizer/zbar where it connects.
Has anybody done this?
Clutch linkage question
- spartman
- 68F250
re: Clutch linkage question
I think they use bushings because the engine moves around too much. Bearings would lock it in place and probably bind up. Now if the engine and tranny mounts were solid, you probably could.
Barry
- spartman
Re: re: Clutch linkage question
That is what I was wondering also.68F250 wrote:I think they use bushings because the engine moves around too much. Bearings would lock it in place and probably bind up. Now if the engine and tranny mounts were solid, you probably could.
