Hi all, I have a Ford diff assembly which measures 52" flange to flange.
The axles that are in the diff assy have the following casting numbers on the inboard face of the axle flange they are as follows;
CASTING NUMBERS ON AXLE ( RH ): CC20W4235D
CASTING NUMBERS ON AXLE ( LH ): CC20W4238D
Diff HOUSING WIDTH ( FLANGE TO FLANGE ): 52"
Any help on the identification, model year etc, of the assembly would be greatly appreciated.
Regards
Oz
Ford axle width
re: Ford axle width
I'm going to guess the factory rear end tag that is usually attached to one of the studs, where the hogshead bolts on is missing? I'm sure the guys here can figure it out with what you provided, but that id tag would definitely help.
Okay guys, what does he have??? Anyone?
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: Ford axle width
Patrick,
Yes you are correct
, and the flange width i gave in the origional post is meaured from flange to flange of the diff housing not from the axle flanges.
Oz
Yes you are correct
Oz
re: Ford axle width
- 57-59 Ford/Edsel - 52"
- 67-70 Mustang/Cougar/Fairlane/Comet/Falcon - 52"-54"
- 65-66 Mustang - 52"
- 66-69 Cyclone - 52"
(The '70-'72 Mustang rearends were 2" wider)
