Transmission Durability
I have the NP435 transmission in my 68 Camper Special and I would like to know if it would hold up to a 427 with 500 horses. I don't want to wreck the tranny if it is too much. Anybody else have that much power on that tranny?
"I didn't mean to wreck him, I was just tryin to rattle his cage." D.E.
- heep70
re: Transmission Durability
I don't think you will have a problem.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 72hiboy4x4
my question is why are you putting in a 427? Isn't that a Ch*vy engine?!?
and I wouldn't try any first gear burnouts if I were you! you'll twist the driveshaft into a pretzel, or worse!
- heep70
Its a modified Ford engine called the Poor Mans 427. Do a search on that.
Greg
- heep70
FORD428CJ is building one. haven't heard from him in a while.
Greg
It's a 427 out of a 67 fairlane. Sweet motor.
- heep70
Wanna trade for a 1.8 Subaru engine? Think of the gas you will be saving.
Greg
Tranny won't break. U-joint's you'll have to keep an eye on.
You probably got 18spline axles in that Dana. Watch that too.
- 390Nut
72hiboy4x4 wrote:my question is why are you putting in a 427? Isn't that a Ch*vy engine?!?
I've got a 1020cc engine that would be even better. Winds up to about 11 grand, too.heep70 wrote:Wanna trade for a 1.8 Subaru engine? Think of the gas you will be saving.
Doubt it would do it very quickly in a two ton vehicle, though
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
I have a one tonne with a NP435, I can't see you wrecking one of these transmissions at all. I have seen my uncle do races with a one tonne with a built 390 (with around 475hp) fully loaded deck & high hab, with both duals smoking off street lights with no damage to the NP trans, but the drive shaft thats a deferent story.
WHAT ?
