C6 Kickdown help with Sniper EFI on FE
Looking for any suggestions on how to setup a kick down lever/cable. I'm installing a Holley Sniper EFI on my 390 with a C6. The kick down stuff from my Carter AFB don't work and the Holley Sniper is setup like Chevy connections. Any ideas would be greatly appreciated.
Re: C6 Kickdown help with Sniper EFI on FE
Lokar ...
I fabricated a bracket to hold the Lokar setup that uses 2 cables: 1 for throttle and one for kick down. The bracket bolts to the 2 factory bolt holes that the original trapeze bolted to on the intake.
Since the Sniper altered the throw and put my pedal too far off the floor, I also swapped to a Lokar pedal assembly that bolts to the floor. It is so much more comfortable.
Whitsend, got pics of your setup. and those that have the sniper, how do you like it?
Zorm,
I think he has some toward the end of his project thread.
Also, cruise the HolleyEFI forums and there is a throttle lever kit folks are using for the travel issues...
