transmission
transmission
hey, guys whats up again,, yesterday, i became aware of the chance to buy a t-18 or a t-19 transmission for my truck {2wd f250}< its automatic, and i want it to be manual, but i know these tranny's have a PTO output, ,, what would that be for? , and im wondering if it would work, besides the bellhousing,and tailshaft? , basically, im just wondering what all i would need to do for it to work thanks __ jeff
"NOTICE, Insanity has replaced all reason in the design and construction of this vehicle"
1970 F250 Sport Custom, 360FE
1964 Thunderbird, 390FE, Offy intake, holley 4bbl,cam, open exhaust
- 72hiboy4x4
well the PTO on my truck runs (ok ran) the front mounted winch on my truck.
but it is installed in the transfer case, not the tranny. which means I had 4 speeds power in, and 1 speed power out, (or was it the other way around?? I can't remember??)
and sure it will work. you need the bellhousing, clutch set-up. pivots on the frame and the bellhousing/engine block, clutch linkage, cluch pedal assy, floor shifter cover, and the proper driveshaft for your truck. then you will want to change your steering column to match. (did I miss anything? probably!)
I've done this swap. with a donor truck or a bunch of scavenging, its pretty easy.
Good Luck!
Good Luck!
re: transmission
thanks mike, im just seeing what all i will need to get together, for my myself to do it, i didnt think it would be hard to do, just a little time consuming, thats all,,, _jeff
- mrung0wa
re: transmission
FYI: PTO stands for "Power Take Off" with a PTO set up you can operate all sorts of implements!
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- mrung0wa
re: transmission
Is that like a 3 point turnabout?
Lawrence
Lawrence
