New Clutch
- boots
New Clutch
I just ordered a new clutch from jegs. I have a 67 f100 with 390..3pd that i put on the floor.. im not sure what kindof trans it is. Any guesses?
well how should i go about putting this clutch in on my garage floor, it is a 2wd, and has a 4" lift so i can get under it easier than a stock 67? Looks like 2 crossmembers are in the way so dropping the trans would be hard, only way i can think of is moving it backwards. Can you guys tell me what i should do, and any tips i can use to get this done without pulling my hair out. its my first time ever installing a clutch, my dad has before, but is real busy with work, so its all me.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- shrektruck
If you're fairly stout you can pull one the front crossmember and drop the tranny out on your chest and kind of wiggle out from under it. I don't recommend it with out a little experience though. Key part is getting that pilot hole lined up good though. Buy the $2.00 alignment tool from the parts store and NEVER, EVER let that tranny hang by the input shaft.
Matt
- jor
re: New Clutch
Try and get hold of a manual so you can get an idea of all that is involved. One person can do it without equipment but like Shrek said, it's pretty hard. Anyhow, here are three photos that show what everything looks like:
1. Pressure plate and clutch bolted onto flywheel;
2. Input shaft of a 4 speed;
3. Sliding the engine onto the input shaft.
Good luck and let us know. (Also, tell your dad to take some time off!)
jor
jor
re: New Clutch
Okay, it's been a while. I had a 67 2wd that was stock height and I could yank that 3 spd out in 45 minutes. But that didn't include removing the pilot bushing.
1. disconnect the battery
2. block the tire so the truck doesn't roll
3. disconnect the driveshaft from the tail of the tranny
4. use some duct tape and tape up the tail to minimize the skunk juice from spilling out.
5. disconnect the stick shift
6. disconnect the speedo cable
7. remove the bolts to the tranny mount and cross member
8. remove the four bolts from the tranny to bell housing.
9. you may have to disconnect the exhaust pipes if they're in the way
10. I use a floor jack to help lower the tranny. It's a bit tricky but I do it all the time. Jack up the jack towards the front of the tranny as that's the heavier end. Lift it high enough to take that cross member out.
11. Once that cross member is out, start to lower the jack a bit. Grab the tail of the tranny and wiggle it while pulling it out the same time. NOTE: I ALWAYS LAY IN A STRATEGIC AREA IN CASE THAT TRANNY SLIPS OFF THE JACK. I never plan to catch it if it does slip. The tranny should separate from the bell housing. You'll need to pull the jack back as the tranny moves back.
12. After the tranny is out, I had to roll it off the jack and drag the tranny out. Since you have a 4" lift you might be able to just pull the jack along with the tranny.
13. If I remember, you could remove the inspection cover to get to the flywheel. If not, then you'll need to remove the starter and bell housing.
14. I recommend that you get the flywheel surfaced. You'll need a flywheel holder or do like me and wedge a LARGE screwdriver to prevent the flywheel from turning.
15. remove all the bolts holding the pressure plate. You'll have to rotate the flywheel to get all those bolts. Be careful on the last two bolts because that pressure plate is heavy.
16. remove the flywheel bolts. Be careful, that flywheel is even heavier.
17. now for the fun part. You need to remove that pilot bushing. Several different methods. There's different types of pilot bearing pullers. You can also use "hydraulics". Can be messy, but it works.
Let me know if you have any questions or run into problems. Let me know if you have questions on installing.
- Freightrain
Faithful has the plan pretty well covered. Lord knows I've done it enough times in my sleep to not even have to think what size wrenches I need:
1/2" for u-joints
5/8" for tranny and bellhousing bolts
7/16" for speedo cable(or maybe 3/8"?)
9/16" for center bolt in crossmember bolt
5/8" for crossmember frame bolts(I think, been along time since I had stock bolts in mine)
11/16" for flywheel bolts
A jack is recommended for getting tranny out. It's near 100 lbs that you need to hold and wiggle to remove and install. Not for the faint of heart. With your 4" lift using a jack might be hard to do.
Most clutch kits come with alignment tool anymore, use it. Then make sure to run fingers around plate to see if disc is even around the edge. The thing is, with the weight of disc, it will still tend to hang a bit when tightening the clutch plate........thus being off a bit(even WITH tool). Just make sure tool slides in/out real easy after you tighten clutch.
Ya, the pilot bushing may be a beech to do. I have my way, others have theirs. Renting a puller from Azone or such will make life easier.
1/2" for u-joints
Bump'n along.
- boots
re: New Clutch
wow thanks for the help!! I will be doing this job over the weekend and hopefully I dont have any mess ups. Ill post how it goes when its done.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
re: New Clutch
I got it out today! I took the tranny out first , then the bell housing. Jegs sent me the wrong clutch, So im getting the correct one next week sometime. I am going to pull the engine this week also, give it some paint, replace oilpan/gasket and some other goodies
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Freightrain
- flyboy2610
Re: re: New Clutch
Yea, I have learned that these trucks had two different clutch styles in them: the 3 finger type and the diaphragm type. I believe they are interchangeable as an assembly, though.boots wrote:I got it out today! I took the tranny out first , then the bell housing. Jegs sent me the wrong clutch, So im getting the correct one next week sometime. I am going to pull the engine this week also, give it some paint, replace oilpan/gasket and some other goodies
Red Green
you'd better be right.
Red Green
- boots
re: New Clutch
they sent me the diaphragm instead of the long style
i even talked to a tech on the phone, he said i needed diaphragm
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Freightrain
re: New Clutch
Ya, usually the diaphram bolts up differently then long style. If flywheel does not have both patterns, you won't get it to fit.
Now, with an aftermarket steel flywheel it would fit right on since they usually have both patterns.
FWIW, my '69 428 has had both type clutches in it(one Ram, the other is Centerforce Dual friction) and they both bolt right on.
Bump'n along.
- willowbilly3
Re: re: New Clutch
Oh no!! it's started, this truck won't see sunshine for 2 years and $10,000boots wrote:I got it out today! I took the tranny out first , then the bell housing. Jegs sent me the wrong clutch, So im getting the correct one next week sometime. I am going to pull the engine this week also, give it some paint, replace oilpan/gasket and some other goodies
- flyboy2610
re: New Clutch
Yup, that's how it happens!
Red Green
Red Green
- boots
re: New Clutch
i have decided not to pull the engine now
. I knew if i did it would be in the garage for another 6 months.... I want to drive it!!!!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
re: New Clutch
Its in
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
