352 tune up specs
- 67F110
352 tune up specs
Is there a good (meaning free, complete and accurate) online resource for tune specs for the 352? Mine doesn't seem to want to run. Cranks, gets fuel, sporadically fires up but won't stay running. Time to get this old girl running and driving. Thought I'd do a tune-up while I figure it out.
- Caseys71
Re: 352 tune up specs
According to my Chitons the specs are as follows for a '67 352:
Plug gap- .034"
Point dwell- 26-31 degrees
Point gap- .017"
Ignition timing- 6 degrees on a manual/automatic trans truck w/exhaust emissions
Int. valve opens @ 22 degrees
Fuel-pump pressure- 4.5-6.5
Idle speed- 625 RPM for manual trans truck w/ exhaust emissions
550 RPM for automatic trans truck w/ exhaust emissions
550 RPM for manual trans truck w/o exhaust emissions
475 RPM for automatic trans truck w/o exhaust emissions
Plug gap- .034"
Point gap- .017"
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- 67F110
awesome... thanks!
how do you calculate the degrees on the timing. My truck only has a point but the balancer has one mark and that is it...
wire brush the balancer and you should see the rest of the marks on it. they get real dirty over the years and get very hard to find and read sometimes. a slightly dangerous move is to start the truck and get wire brush up from under neath and let it rub the balancer and clean it off for you. be careful of the fan blade.
great advice, i will try that tonight. I have an electric fan so no worries about the blades.
- 67F110
For the sake of posterity... tune up specs for the 1967 F100 can also be found here:
http://www.fordification.com/bumpwiki/i ... ifications
