Need help with first motor swap!
Hey, in a few weeks i am going to attempt my first motor swap and i need advice as to what all goes into this. what all has to come off, does the trans have to be pulled as well? I am taking out a 300 i6 and swapping it for a 240 i6. im not sure what all has to be done. also, it has a 3 speed on the floor.
Thanks, nate
Thanks, nate
I swear momma! The tires just spin by themselves!!
1969 F100 SWB 300
2002 mustang 5 speed
1969 F100 SWB 300
Re: Need help with first motor swap!
just the enigne is all the needs to come out. disconnect and drain the radiator. pull the radiator. remvoe the heater hoses. remove the fuel lines and wiring. remove the gas pedal linkage. remove any vacuum hoses that dont stay with the enigne. remove the exhuast pipe.
- 70_F100
I have to ask, why are you going from a 300 to a 240?
The 300 is twice the engine that a 240 is. More torque, more horsepower, and probably about the same fuel mileage.
That's not an oil leak
- Redcap
70_F100 wrote:I have to ask, why are you going from a 300 to a 240?
The 240 is no slouch, just not a hot rod. It will pull one hell of a load. I would not care which one I had if I could get one. My Daily Driver is costing me so much in gas that I am having a hard time getting it the parts it needs.
alright, it doesnt seen that difficult.
The only reason that I'm going from a 300 to a 240 is because my 300 needs some major work right now and i just dont have the money to fix it, so i found a 240 thats in good running condition for free that i'm going to use until i can totally rebuild my 300.
1969 F100 SWB 300
1969 F100 SWB 300
Now I do it just a littel different because I have a bad back and hate working under the truck.
I pull the hood, drive shaft, exhaust at manifold, wiring, clutch linkage and transmission rods and pull the engine transmission out together. That way I can separate them on the floor and have it a lot easier putting in the new clutch or whatever else I will do to it. This is about like Holley or Edelbrock. Split as to how people do it.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- michael69
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
depends if my lift goes high enough I pull a manual tranny and engine together. Autos I leave the tranny in place.
Walhalla SC! Not heard that in a while
. I worked at Oconee Nuclear off and on for about 10 years. We ate in Salem many a times not far from you. Lovely country. Always came and went by Scenic hwy 11. I worked on putting in the main electric generators at Bad Creek numbers 1 and 2. Swear to this day I saw Willie Nelson walk out of a store with a case of Bud lite near the house we all rented while working at Bad Creek.
Worked at Jocasee Hyrdo a lot as well.
I guess I have a pretty good lift. It was giving to me by a friend who wanted one that breaks down. Plus I have not pulled an engine from a 4x4 with large tires and lift as I am sure that would make a big difference. Though I might would let the air out of the tires since I hate working under a truck trying to line up everything.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- michael69
Yea, I live on Hwy 11 between Salem and Walhalla. I also worked a bad creek project. I worked on the west dam.And the guy you thought was Willie, That was more than likely Hippie Joe. Was he driving a nice 70 SS Nova.My dad retired from Oconee Nuclear Station. Small world like Salem SC.cdeal28078 wrote:Walhalla SC! Not heard that in a while. I worked at Oconee Nuclear off and on for about 10 years. We ate in Salem many a times not far from you. Lovely country. Always came and went by Scenic hwy 11. I worked on putting in the main electric generators at Bad Creek numbers 1 and 2. Swear to this day I saw Willie Nelson walk out of a store with a case of Bud lite near the house we all rented while working at Bad Creek.
clint
Michael69
