So I have the casting #s off of the intake manifold in my grandpa's '72 F100. Can anyone translate these for me?
Here are the #s: C9AE 9425-B
Thanks.
Intake casting #s question
1972 Ford F-100 2WD 131"wb
Sport Custom cab w/ Explorer trim package D
Seqouia Brown Metallic with Ginger Random Stripe cloth and vinyl
360 FE block w/ C6 and Ford 9"
100% all original, until it gets restored.
- Hawkrod
Re: Intake casting #s question
That casting number only tells you when a part was designed, not when it was used. Your manifold was designed for a 1969 Ford full size car but the same manifold was used on cars and trucks for several years and is likely original to your truck. You will need to find the casting date which is also on the manifold to determine when it was made. The casting date will look something like 1K27 or 2C3 (the examples translate to November 27, 1971 and March 3, 1972). Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
