Heater hose routing
OldRedFord
Heater hose routing
Post by OldRedFord »
Do I have my heater hoses ran right? Or does it not matter?
The side with the valve runs to the water pump.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
gregamorton
Re: Heater hose routing
Post by gregamorton »
your worried about water hoses? Looks like you have a rat moving in on the passenger inner fender! :lol:
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
OldRedFord
gregamorton wrote:your worried about water hoses? Looks like you have a rat moving in on the passenger inner fender! :lol:
Baby birds, I bet they will be gone by Wednesday, getting big.
Tim
Good evening Tim,
That's very kind and admirable of you to work around the birds, taking care to not disturb them like that.
With regarding to your hose routing, I'm searching for photos of a truck that are somewhere on FORDification.com of a truck with only a few hundred miles (or maybe less). I'm pretty sure Keith posted them (he may have found them in an eBay ad, if I'm remembering correctly). It's a blue truck. It has a great reference engine compartment!
DirtyJim
Post by DirtyJim »
Those are swapped from what I can tell, but Im not sure it matters or not.
DirtyJim
Post by DirtyJim »
The hose that connects to the T on the manifold should be the one with the heater control cable connected to it.
Dragon
Post by Dragon »
The water pump side is return water inlet. The manifold side is water to the heater. The water pump won't have hot water in it until the thermostat opens. The bypass just lets enough water across to protect the pump.
Montana71-F100
Post by Montana71-F100 »
With the hood on I couldn't get far enough from the engine to get everything in one shot. This is a '71 360. The hose on the lower left goes to a tank heater. One hose passes under the automatic choke.
Dragon
Post by Dragon »
When you have a carb heater you go from the Intake to a t and one leg of the T goes to the carb heater. The other leg goes to the valve for heat control then into the heater. The carb spacer water outlet on some trucks cam back to the water pump and was tee'd to the return from the heater core at the front of the engine. Others were Tee'd to the return hose up by the firewall.
jf100
Post by jf100 »
I am trying to find out where to run my heater hose's and which hose has the control in it. The photo bucket pic is all blurry I have a 69 f 100 with a 302 engine. I have been rebuilding it and life and money got in the way. Do not remember which side the control went on and there was and H fitting in the hose's as well can not remember if that went to the cab side of the control or the grill side. Any help would be great thank you for your time and wisdom.
jf100
sargentrs
Post by sargentrs »
This is for the A/C install but shows the heater hoses too. http://www.fordification.com/tech/image ... tegral.jpg
