Gas tank
OldRedFord
Gas tank
Post by OldRedFord »
The bottom bolts that hold the in cab tank in. Where are the back of the bolts? Is the cab floor right under the tank boxed in or something? I need to get to the nuts that hold them on.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Dragon
Re: Gas tank
Post by Dragon »
On mine they are pal nuts embedded on the floor.
bmerkley58
Re: Gas tank
Post by bmerkley58 »
The bottom seam of the fuel tank sets in a groove on two plates that are bolted down with the rear cab mounting bolts. If you have the upper row of bolts out you should be able to lift the tank straight up to remove it.
Bob
Re: Gas tank
the 70-72 has nuts tack welded to the floor behind the seat. the 67-69 has the plates that the tank sits in.
