302 questions
Joshpow
302 questions
Post by Joshpow »
I got you engine whizzes a few questions. I got offered an 89 302 that is fresh machined the other day. My questions are :::
Will an 89 302 work with a 75 c4 auto?
Will 89 heads work with a 72 block?
With 89 heads on the 72, will my edelbrock z89 intake work?
I dont want to waste time on a useless engine, so if parts or whole wont interchange, I dont need it. Any info is great. Thanks guys.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Re: 302 questions
the engien will bolt up to that trans. and i cant see any reason the heads wouldnt fit on a older block. i would think the intake would work.
flatblack
Re: 302 questions
Post by flatblack »
they will all work providing you have the right balance of flywheel with the c-4 and backing plate for the c-4, i believe 74 had a different balance than 89.
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
Ranchero50
Re: 302 questions
Post by Ranchero50 »
89 302 used a 50oz imbalance flexplate. You'll have to find a C4 on for it. Usually Summit Racing is the source.
cdeal28078
Re: 302 questions
Post by cdeal28078 »
I cannot remember if it was the 351W or 5.0's that changed the number of intake mounting bolts on the intakes and heads. Bet it was the 351W but might have been both. It'll still work though just might confuse you. There might also be a difference in the intake gaskets around the water passages.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
