When I was putting it together for the second time I stripped out the 1/4 hole in the front cover for one of the bolts.
I would like to avoid dropping the pan again if I can.
I tried to run a 5/16 tap in the hole but I could not get it to start square, and can not get a tap handle on it either with the pan on.
I had to take the pan off the second time after I changed the gasket out because when I was rolling the motor right side up on the engine stand the oil pump shaft fell out of the oil pump and when the engine was upright it fell back in but missed the pump....
Sucks sometimes always working on things with no help.
