Rookie timing question...
Oxblood
Post by Oxblood »
How do I time with this style timing cover?
Crappy cell phone pic but I think you can see it.
I tried pulling the pointer off my 1972 302 engine but I couldn't bolt it on because the casting was different.
Thanks,
Oxblood
Re: Rookie timing question...
i can tell that eninge is a 302 or a 351w. by lookign at the motors moutns. maybe that cover is off a late rmodel enigne. and has a different timing pionter. the one on my 94 5.0 is different than any early small block covers i have seen before.
to add to that. the casting number on the timing cover is probably behind the water pump. that numebr woudl tell you what timing pointer to use.
Oxblood
Post by Oxblood »
It's a 302/C4 outta of a van the PO put in, the trans is a 74 so I'm thinking the engine is also. I think the easiest answer might be to pull the timing cover/pointer/harmonic balancer from my 72 302 and put em on, any opinions? I think the timing cover is leaking anyways so maybe I'll get a new timing set and make it a project...
is it possible the pointer is on top on the drivers side maybe? since the enigne came out of a van? if nto im sure you could do that swap and it should work.
Oxblood
Post by Oxblood »
Can't find anything on the driverside. I'll turn it over to tdc and see where the scale is to locate the general area the pointer should be
cdeal28078
Post by cdeal28078 »
Can you get a picture from the top on each side? Where is the oil dip stick located? Is it a mechanical fuel filter? That might help also.
I think there are at least 2 maybe 3 different set ups on the 302/5.0 engines as far as the timing set up goes.
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Oxblood
Post by Oxblood »
Theres a bunch of stuff in the way from the top: alternator on passenger side, water pump outlet/ mechanical fuel pump on driver. The oil dip stick is on the driver side between the rear two cylinders. I rebuilt the carb (Holley 4160) twice but its backfiring no matter what I do so I would like to get this thing timed right.
cdeal28078
So that is a later engine probably mid 80's I would think. Somebody put an early timing cover on it for the fuel pump opening and left the dipstick on the side of the engine. There might not even be a timing marker on the timing cover just depends on what they did. Even if it has a marker did they use the right balancer that would line up with the marker. I think we are going to need either some part numbers for the number guru's or some pictures for people like me that don't know the numbers.
I doubt you have a 71 302 in the truck. More than likely a mid 80's. If you look just above the starter from underneath you will find some letters and numbers. They will give us a better idea of the year engine you have
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
