d0ve-c headwork
bb429power
d0ve-c headwork
Post by bb429power »
How much can you port d0ve-c base heads for a 1971 429? I would like to get rid of that lip just on the inside of the intake ports. But the wall of it looks pretty thin. Also what are the largest valves you can put in it without boring the cylinders? My machinist says the max he can go is 2.12 intake and 1.76 exhaust, but I've heard people put a bigger intake valve in it. They aren't cobra or super cobra heads. And by the way, if its just a base block then is it considered a thunderjet? Think so just want to hear you input.
Here's the lip, you can kind of see it like a quarter inch in. What is that exhaust passover through the intake for?
What does the number 13 mean?
-Thank you :D
Justin
1986 f150 5.0 (my DD)
BobbyFord
Re: d0ve-c headwork
Post by BobbyFord »
Do yourself a favor and join Scotty's site: http://www.reincarnation-automotive.com/index_2.html
For a one-time $25 subscription fee you can learn all you need to know about porting 385 series heads. Scotty has gotten 730HP out of ported iron D0VE heads.
The number on the block is just a casting number. 429's and 460's both had a 460 casting in that same spot (some had a 460 mirror image). To determine whether yours is a 429 or 460, look at the crank casting number found on the side of the front crank throw:
429: 4U, 4UA
460: 2Y, 2YA, 2YAB, 2YABC and externally balanced '79 and later 460 crank has a 3Y casting.
bb429power
Re: d0ve-c headwork
I know it a 429 for sure, but i was wondering if the 13 stood for the thirteenth built (doubt it) there's also a thirteen on the trans so they are matching. :woohoo: I discovered that website a couple of weeks ago. Thought it was pretty cool. Thanks.
Justin
Hawkrod
Re: d0ve-c headwork
Post by Hawkrod »
13 is the mold number. All molds were numbered so if there was an issue they would know which ones to pull. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Doug F
Re: d0ve-c headwork
Post by Doug F »
The old trick was to blue the head face and take a head gasket and scribe the head face with the gasket port shape, then take a high speed grinder and "gasket match" the head, then do the same to the intake. Be sure to just taper it in, otherwise you can break through to the water jacket :nono: Also, don't think about polishing them, it hinders the atomization of the fuel and causes "wet-out"
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
eggman918
Re: d0ve-c headwork
Post by eggman918 »
:yt:
As little metal removal as is possible , all you want to do is lessen the turbulence at the gasket
not to change/enlarge the runner,unless you know what you are doing :2cents:
It is EASY to screw it up :eek:
Steve
cdeal28078
Re: d0ve-c headwork
Post by cdeal28078 »
BobbyFord wrote:Do yourself a favor and join Scotty's site: http://www.reincarnation-automotive.com/index_2.html
429: 4U, 4UA
I 2nd the motion of joining Scotty's site. There is all kinds of info on there about the 385 engines not just head porting. Well worth the $25 to join.
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Dragon
Re: d0ve-c headwork
Post by Dragon »
They sell 2.25 intakes for it Like the ones for my EDC heads when installed they will get cut down to 2.23. So it is safe to assume you can get close to 2.25.
bb429power
Re: d0ve-c headwork
Doug F wrote:Also, don't think about polishing them, it hinders the atomization of the fuel and causes "wet-out"
HAH!,I knew it. I always had this theory that a rough port would be better because it would help atomoze and stir up the air/fuel mixure. :yip:
Justin
bb429power
Re: d0ve-c headwork
Here's the heads. Valves are going to be 2.12/1.76. Still have to grind some stuff down and pocket port. :D
Justin
Dragon
Re: d0ve-c headwork
Post by Dragon »
We used to work them smooth as glass for blowers and then because my shop was good at doing that super polish we would shot peen the intakes to slightly roughen them up.
Doug F
Re: d0ve-c headwork
Post by Doug F »
Sure polishing your ports has its place... Polishing the exhaust ports is ok, just not needed and takes a LOT of time. Forced induction and port fuel injection are also prime candidates for polishing, carbs need all the help they can get to keep your fuel flowing and not leaning out cyls!
Mighty fine lookin heads you got there!
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
