cam lube?
hotrod ford
cam lube?
Post by hotrod ford »
i got my engine machined awhile back and the fella did not not put any lube on the cam. should i just remove it and do it while its out or can i do it while it is in the block? the only things on the eng is the cam, crank and heads.
eggman918
Re: cam lube?
Post by eggman918 »
clean it, lube cam lobes, lube lifter bottoms and finish assembly :2cents:
Steve
Re: cam lube?
I would pull it out and lube it... :wink:
hotrod ford
Re: cam lube?
DuckRyder wrote:I would pull it out and lube it... :wink:
i thought so. thanks. :thup:
