I have a Holley 3310 that I am going to use on my 460. There are three vacuum ports. In the instructions it says to hook the PCV hose to the PCV port, but which is it?
PCV question
- OldRedFord
PCV question
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- ToughOldFord
Re: PCV question
None of those, they are all way too small. PCV uses a 3/8" hose IIRC.
Edit: Now that I look closer it may be that first one if it is actually larger than it looks in the picture. It is in the correct location and the power brake booster gets it vacuum off the manifold, not the carb.
Fordman, that last pic isn't very good, but it looks like a 1/4 or 5/16 fitting to me.
Re: PCV question
i couldnt even see the size of the bottom port. i just said that because that is the normal place for it to go.
Re: PCV question
I have a 3310 on my 390 and the pvc port is the one on rear of the base plate. The one on the front of the base plate is also full vacuum but on my 3310 it is a smaller port opening. I use the front one for full vacuum to the auto trans. shift diaphram. I have had mine hooked up this way for years and no problems. Also I use the front port when I use my vacuum guage. The port on the metering block goes to the vac. advance on the dist.
- eggman918
Re: PCV question
mine is set the same way and is running properlygeorge worley wrote:I have a 3310 on my 390 and the pvc port is the one on rear of the base plate. The one on the front of the base plate is also full vacuum but on my 3310 it is a smaller port opening. I use the front one for full vacuum to the auto trans. shift diaphram. I have had mine hooked up this way for years and no problems. Also I use the front port when I use my vacuum guage. The port on the metering block goes to the vac. advance on the dist.
Steve
- BobbyFord
Re: PCV question
The first pic was the PCV port.
