need help identifying what size motor...
67_trickedout
Post by 67_trickedout »
on the back of the block it has the numbers 66-427. on the front of the block it has the numbers 57 and 352. on the tappet covers it has cobra le mans. this is my buddys motor. he was told it was a 390 and i find that hard to believe bc i have a 390 in mine and have a lot more room to work around. im thinkin its between a 427 and 429
BobbyFord
Re: need help identifying what size motor...
Post by BobbyFord »
No, it's not a 429, not with those casting numbers. If it were a 427, you would see the cross-bolts for the 4 bolt mains on the side of the block, just above the oil pan. 427 has the same outside appearance and dimensions as a 390 (as do all of the FE's) The only way to tell would be to stick a wooden dowel down one of the spark plug holes, carefully rotate the engine by hand and measure the stroke. It could be 352, 360 or 390.
SoCalExile
Post by SoCalExile »
SoCalExile wrote:Does this link help?
http://www.carcraft.com/techfaq/116_990 ... ndex5.html
This must have been written by a chevy guy.
(quote) These two ribs (arrows)at the back near the distributor clearly distinguish this as a 351 Windsor.
I'm wondering how accurate the rest of the article is. :hmm:
This one is probably more accurate, although I think we already determined it is an FE...
http://www.fordification.com/tech/engineID-V8.htm
michael69
Post by michael69 »
:yt: If the distributor is at the back it surely is not a 351w much less a ford at all so I think I wouldn't use that info!!
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
ToughOldFord
Post by ToughOldFord »
Oh yeah, smells like a Chevy guy:
Ford FE Series
The FE series of engines, produced in displacements of 332, 352, 360, 361, 390, 406, 410, 427, and 428 ci between 1958 and 1976, has a five-bolt valve cover and Chevy-style water pump and is also identifiable by its intake manifold, which forms part of the valve cover surface.
Redcap
Post by Redcap »
ToughOldFord wrote:Oh yeah, smells like a Chevy guy:
Ford FE Series
Clearly an idiot.
if you think abotu it. the chevy water pump bolts to the blcok with 4 bolts just like a fe does.
OldRedFord
Post by OldRedFord »
Something tells me this paragraph is full of misinformation also...
For example, both the 429 and 460 big-blocks (385 series) and the 351M and 400M share identical blocks and heads.
RIGHT
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
sometimes you have to read through what others post. 429 460 . 351m 400. that is probably what he meant. always get more than one source for information.
AlleyCat
Post by AlleyCat »
michael69 wrote: :yt: If the distributor is at the back it surely is not a 351w much less a ford at all so I think I wouldn't use that info!!
:) Michael, FYI, Ford's first overhead valve V8's ( commonly known as Y-blocks ) have the distributor at the rear of the engine. :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
michael69
Post by michael69 »
:oops: forgot about that!! :thup:
Michael69
Dragon
Post by Dragon »
There were a few non side oiler 427s in 66 and 67. They came in low end Galaxies with Single 4V. If a 427 came with Medium or High riser heads then they were always 2-4v and side oilers. But low riser heads were always Single 4V
dustman_stx
Post by dustman_stx »
fordman wrote:if you think abotu it. the chevy water pump bolts to the blcok with 4 bolts just like a fe does.
Then that means that the Chevy's use an FE-style water pump. Duh.
